Hi people,
I have had the boiler for nearly 12 years (credit to Worcester)!
Last year I had an issue with the Diverter Valve so I replaced it and no problems, at the time due to the age I also changed the Overheat sensor, CH Sensor and DHW Sensor. All running fine.
Roughly 1 month ago the flashing red Light (Hot water LED) started flashing, after some investigation I changed the Air pressure switch and the hoses, problem fixed.
I'm now suffering with a Hot water issue, when running the hot tap it gets very very hot then the boiler ignition light goes out, this then repeats itself. The only way I can get it to run is if I turn the dial down on the front to 1/4 (min side).
The CH runs fine as does the Fan, do the think the DHW sensor has gone faulty?
Your Ideas would be apprieciated
