Hi guys..... we have a Worcester 28cdi which suffers from the following problem. It has happened 3 times now. After it fires up and heats the hot water for approx. 6 -7 minutes, it then shuts down following 3 or 4 banging noises which I assume is water boiling and the system recognising this. The water pressure on the dial goes up from 1.5 to 2 bar. I've opened the air vent on the top of the boiler and this releases the pressure. Upon removing the chrome cover screw from the pump, I've found this also under pressure with water forcing out from there too. After a few minutes the boiler fires up again so I'm guessing this is due to a fail safe cut out in the boiler. Could it be as simple as a tired pump that needs replacing?
The boiler had a heat exchanger replaced about 3 years ago....other than that its been problem free since it was installed in 2000.
Thanks in advance fellas ........ Eric
