worcester 28i greenstar pressure to high
12 Dec 2007
Lancashire
the pressure on my worcester 28i greenstar is going to high and the PRV is now letting out the water, the DHW pipe seems to have a constant flow of water also. my heating works fine so does the hot water. can anyone help
thought it was filling loop so fitted a new one and it is exactly the same, the loop itself needs the key in to make it a loop so it can not be that.
if i turn the small screw tap to cut off the DHW suply then pressure stays level but but with no hot water and as soon as it is open again pressure rises
that is what i thought, i think i read in my manuals that it is covered by a 10year waranty is that right
was never told to by the installer, as he went on holiday and did not really tell us anything about it. just fitted it ruined a few new carpets and left us to it. had to ask another fitter how to repressure the system after a couple of days as it had dropped
what does a service consist of on a central heating system, i thought it was just water in there
Its the boiler that is serviced not the pipes and rads.
look in you service manual and its in ther what shuld be done.
