The power was off for 20 minutes and now have no heating or hot water, blue light is flashing and it all sounds as though it is working but no pilot light coming on
Check your boiler manual, it will instruct you how to reset the boiler.
It should be - drop down the front panel, there will be a flashing reset button on the right hand side. Press and hold this for 5 odd secs. The reset button will go out and the blue power light will go steady on.
If that doesn't work then time to call someone in.
