HI, boiler is approx 18mths old, have removed two radiators for decorating and shut of feed to and from the radiators. the boilers pressure has shot up and although can be released, pressue increases straight away. (normally have to top up the pressure every so often!)
also water coming from boiler overflow. only way to stop it is to turn water off, which does have an effect on the pressure dropping. last night, pipes were rattling and water being ejected from the overflow at an almighty speed. Is it because i have removed radiators and will it rectify itself when i replace them? or is there a fault with the boiler? I have bled all the other radiators and doesnt seem to be an airlock. Please help.
