Hi chaps
Really hope someone can help?
My boiler seems to work fine apart from when I’m using the hot tap in the bathroom which is furthest from the boiler pipe wise in the house, sometimes half way through a shower the boiler switches off, but if I then turn on the hot tap in the sink ( next to the shower ) it fires up again..I’m pretty sure the fault has to do with the water pressure detector sensor ( i.e the tap being turned on ) but I have no idea where that is on the boiler ?
The other thing which happened yesterday is when I had the hot tap on in the sink ( right next to the boiler ) and then I turned the cold tap on again the boiler turned off the heating..again I think this was because turning on the cold tap dropped the water pressure of the pipe going into the boiler so it thinks I had turned the hot tap off.
Any ideas ?
Any ideas ?
