Hi all
I have a Worcester 28i RSF. It works perfectly but I wanted your advice on the temp setting. It has a dial on the front which allows you to set the heat (power?) of the heating. It ranges from off to '4' with 4 being the hottest.
Now from an efficiency point of view what setting should I use?
Typically I always used 1.5-2 on the dial, but a friend of mine mentioned that boilers are most efficient on their max setting which I'd not heard before and I wanted to confirm what setting is generally best.
Many thanks
Many thanks
