hi there ive had the above boiler in house for 5 years but i only have a programmer on the boiler . i was wondering about fitting a room thermostat thought it might help save more gas fitting one , whats better a digital one or just a dial one, i was looking at the drayton rts8 says combi stat , or the hortsmann drt1 digi one . so are some stats specifically for combi boilers? the boiler has three wire connectors annd do you get wire with the stats to run to the boiler ?if not what cable should you use ? thanks paul
