can you please help me, my Worcester 3.5 high flow gas boiler will not start. is there a lockout button to reset it and if there is could you tell me the location
If a remember rightly there are 2 overheat buttons. Remove the front cover and underneath the main control box casing (not inside the casing) the buttons are left and right. They're dark red in colour and will only move about 2mm when you push them.
