Worcester 35 CDI II, fitted about 2005, serviced about a year ago according to previous house owners.
We have done a lot of work in our new house. We were moving a some rads. The boiler was switched off and drained down, gas was turned off and left for about 3 months.
Today I refilled the system and turned it on until the rads started to get warm, then turned it off and checked for leaks and left it for half an hour and there was no pressure loss. I then drained down the system from a drain valve on the CH return just under the boiler. The water that came out was quite clean, a little white but really quite clean. I then put 500ml of "No Nonsense" inhibitor and 500ml of leak sealer as it looked to have a little leak out the back of the heat exchanger. I then refilled the system to 2.5bar as stated in the manual and turned it on. The rads heated up quickly and got nice and hot.
The hot water got hot nice and quick but is cycling hot and cold. The demand light is staying on while a hot tap is open but the burner is coming on and off. When the water is off the burner seems to stay on. The lights don't flash to indicate a problem.
From reading this site I think it is either a clogged heat exchanger or a broken thermistor for the hot water. Does this sound reasonable? What should the resistance of the thermistor be?
Any comments or suggestions gratefully accepted
Adam
Adam
