Can anyone help with my Central Heating problem?
I've recently moved into a late 70's house fitted with a Worcester 350 Highflow Combi boiler / 8mm microbore pipework. The house has laid empty for upto 2 years.
Following a replacement timer being fitted, the Central Heating functions (all rads heat well), but there is a servere sound of air flowing in the pipes in the upstairs rooms. I've bled all the rads with no air being released. From reading things of the Net, it seems that Combi systems are sealed water systems, but I've got a small water tank in the loft and I can't see a pressure gauge!
Also, water flow rates from the taps are very poor (especially the hot water upstairs). The water flow rates in the bathroom vary relative to the hot / cold taps being turned.
If anyone has any comments I would be most grateful. Are flow rates normally poor with Combi systems? Is the Header Tank normal?
Chaoswill.
Chaoswill.
