Hi All,
First post, so please be gentle. My faithful Worcester 350 has started to knock out the overheat button. This only happens after running the hot water for a long time e.g. bath / shower. It's fine on central heating.
Looking at the instructions, looks like overun should keep the fan ( or perhaps fan + CH pump ) running for 2.5 mins. I can hear than fan run for approx 5 seconds, then the overheat pops out, leaving boiler dead with no lights.
When the boiler cools down, i reset the overheat, and the fan ( sounds like fan ) does indeed run for 2.5 mins.
Any advice welcome ( electrical only as wouldn't touch gas )!
Seem to be hearing different opinions from plumbers cover a faulty pump, central heat sensor, blocked heat exchanger driver board. I could spend a fortune getting to the root cause!
Cheers, Currybum
Cheers, Currybum
