Hello,
Here is a challenge i would like to ask you knowledgeable people for help with?
I have an old (1993) Worcester 350 combi boiler.
CH is working faultlessly.
i've used google, searched this site, the FAQ's and all the previous posts i have been able to find - without finding a solution, so far...
PROBLEM - DHW side has stopped supplying continuous hot water.
DESCRIPTION - A hot tap is turned on,
the green demand light illuminates, relays click, the fan runs, the burners ignite and fire up.
warm water comes from the tap for maybe 20 seconds,
the water from the HW tap starts to slowly reduce in temp until cold.
during this time, the boiler is still in operational mode ie, the burners are still alight and the DHW pump is still running.
once the HW tap (with cold water coming out!) is shut, the boiler ceases DHW mode, and after a delay of approx 2.5 mins the CH
resumes.
list of things checked so far -
i have read through the manual with the operational flow diagrams (the installation and servicing instructions) and have been step by step through the fault finding section:
the flow switch sends a signal/operates (tested by removing the unit from the DHW pipe - the DHW system stops running).
demand indicator (green) lights up.
fan comes on - high speed + drops to low speed
the HW pump runs.
gas valve operates, sparking starts, burners ignite, sparking stops.
warm water comes from tap for short time, then becomes cooler.
i have changed some parts on the boiler in the past,
driver board once,
sequence board twice,
relay on sequence board once (cheaper than a recon board!),
DHW sensor once,
pressure releif valve twice,
expansion vessel once,
system flushed every two years,
water to water heat exchanger flushed.
This current challenge has me stumped!
Have i missed something simple? (hopefully!)
Have you experienced/fixed this problem?
How do you think i should go forward with this?
what other parts could I check?
Thanks in anticipation for the sharing of wise words and experience!!
austin
resumes.
the HW pump runs.
driver board once,
DHW sensor once,
austin
