Hi Guys, Please could you advise? I can only get the burner to light with the top cover removed. In both Heating and Hot water modes. With the cover on I get slow red light flashing. As soon as the cover is removed the system works perfectly . I have cleaned the fan and venturi and all pipes leading to the Air Pressure Switch are fine . The Flue is also clean. All electrical connections are fine. The Fan seems to be running fine and is smooth and quiet. Would I be correct in thinking that the Air Pressure Switch is at fault?
Thanks in advance
Andy
Thanks in advance
Andy
