Hi all,
I have a Worcester 9.24 Electronic BF that does not have a timer or a room stat installed; it only has the main control switch on the boiler itself for setting water / water & heating / off.
I'm looking to fit a timer or even just a room stat to this boiler, but don't really want to get someone out to do it as the boiler is old (and I am a competent electronic engineer, so should be able to manage this ).
The question is - where does one approach connecting a timer / stat to this boiler. I have the MI doc, and it indicates that the boiler has a three pin connection for a room stat - but nothing for a timer / programmer. I assume you could break the switch wire for the Heating signal and use that for a timer / programmer feed, but would appreciate anyones advice!
Regards,
Andy
Regards,
Andy
