Please help!, I have a Worcester 9.24 electronic combi boiler which has started to blow the 3amp fuse intermittently when the hot tap is turned off. The Heating works fine & The fuse never blows if the heating is on when you turn the hot tap off it only happens when you are using hot water only & only when the tap is turned off, there are no water leaks , any ideas
