worcester 9.24 problem
28 Feb 2009
Wiltshire
i have a worcester combi 9.24 boiler in my flat 15 years old in quick succesion the pump gave up the ghost then the diverter valve needed replacing now i have a new problem which goes like this hot water and heating is very hot even when the temperature dial is at its lowest point if i move the dial up to anything near the max the pressure starts heading up eventually cutting out boiler i replaced the bits myself and have read that you should bleed the heat ex could this be problem or expansion vessel any ideas?
Your boiler is very old!
Pumps usually fail due to dirt in the system.
The diverter fails or jams after a number od years and due to dirt..
High temperatures usually indicate a failure of the control system.
Tony
With you "changing," the bits yourself I guess you regularly serviced the boiler as per MI's :confused: every year? I am surprised it has lasted this long without proper maintenance... Those parts are quite a few pennies, I wouls recommend you consider a new boiler. New money into an old boiler isn't cost effective if it is over 10 yrs old.... But, on a plus point, iy has had a good innings :cool:
