worcester boiler 24cdi building up presure
20 Nov 2004
:confused: boiler works fine, however the pressure builds up, and needs releasing when it starts dripping. What do you suggest that I do?
There's a pdf document about expansion vessels HERE that may help.
If your pressure does not fall but stays at 3 bar plus then its your plate heat exchanger that passing primary to second , if the pressure does fall to well below 1 then back to 3 when the central htg is on then its prob your expansion vess as said above.
