I
ianblue
Help Worcester 240 Combi. Water leaking from pressure discharge pipe.
Boiler still working but pressure 1/2 Bar
Thanks for that but what would the cause be.
Lack of proper maintenance.
Not likely as the pressure relief valve would discharge before pressure vessel damaged.
If they overpressurised it cold, then when hot it's going to go over 3 bar and discharge, I would check pressure is at approx 1 bar cold and see where it goes when hot, if it goes over 2 bar when hot then pressure vessel probs.
I suggest getting in guy who does your landlords gas safety certificate to look at it.
Boiler is serviced every year! Any more hypothetic reasons?
There should be a washing machine-style tap at one end, and a non-return valve on the other. As you say, the filling loop should always be removed (to comply with water regs if nothing else), but 9/10 I've seen aren'tThe flexible fill hose should have been removed but this was not possible as there was only one side having a valve fitted.
