Hi. I've got a problem with a Worcester Greenstar oil boiler. Both the water and the heating are on timed mode and both are activated in the morning but only the hot water fires up the boiler. To get the heating to work I have to override to switch off the water and then the heating will work (diverter valve moves to heating position) and then I can switch on the water again and everything appears to work correctly. If I set the Heating to come on by itself nothing happens but if I switch the water on and then off the Heating fires up the boiler. Again I can switch the water back on and everything is normal. Could this be a problem with the diverter valve or maybe the programmer/timer? I would appreciate some advice. Thanks.
