Jerry,it could be a build of sludge in the system, which has caused the heat exchanger to stop the water flowing through as it should and its building temp right up and as the sludge has nowere to go its getting very hot and the o/h stat is coming in.The worscter 240 was really well known for its secondry heat ex to block up and cause o/heating proplems.how old is the boiler and is the rads older or same age
Zimmers,The boiler is ten years old.The rads are about the same age.
Nowt to do with hard water then.It trips out on both the heating and hot water.
gerry i honestly think its your secondry heat ex the white roundish part with 2 pipes either end.its blocked up now what id do is get it changed ,ive tried to powerflush them clear but no good ,you can try putting some chemicals in and leaving for a while,but its classic signs of this being sludged up
Zimmers,
I've tried the heating this morning.It's been off all night and is stone cold.If I turn the mains switch on the fan runs for a few seconds and then cuts out.The o/h switch has been reset.This stays down.After the fan cuts out there is a constant click as if a switch is switching in and out for about 20 seconds then this stops as well.All seems a bit weird to me.......
I'm with Zimmers, on this one.
Pump - when the ch comes on, does the heat get round the rads?
