I just found this forum and hope someone may be able to help so thanks for any replies
The boiler is a Worcester Senior 6 B/F Combi that has had both a new overheat thermostat and thermocouple fitted recently. After a few hours of running 7 radiators apparently normally it just shuts down and the pilot goes out. It also shuts down after running the hot water and then turning it off - ie when it is switching back to the central heating system. Whilst going through the possible faults before the overheat was changed the engineer linked-out the overheat thermostat and the boiler worked fine and kept going even after running the hot water - hence the replacement. As the problem persisted and the TC was approx. 5 years old the next thought was the voltage from the TC breaking down but as this has now been renewed I am a bit stumped! It is not shutting down due to the overheat kicking out and relights without problem after it has shut down. I suspect a faulty gas valve but would welcome any thoughts. The boiler must be at least 16 years old.
Thanks.
Thanks.
