I have been hunting through old questions but can't seem to find the answer to this - apologies if I've missed it somewhere.
I have a Worcester 24SBi on a sealed system which serves the central heating and hot water (in pressurised tank). Boiler is about 2 years old and up until 2 days ago has been working everyday with no problems at all.
Now when the boiler switches on it heats up the rads but after about 10 mins it starts banging and clattering, the pressure gauge goes crazy and it cuts out. If you leave it for half an hour or so - and do not reset the system - it will fire up again and go through the same process again.
I had an engineer out yesterday. He took the front screw off the pump and twiddled inside. It then worked fine all the time he was here and he said the pump had probably got stuck and should be OK now. Inevitably it only broke again after he left.
I have rung them back and they tell me the system needs inhibitor and then flushing a week later. Some of the messages I have been reading on here that mention similar symptoms speak of problems with the boiler stat. Can you tell from my description if it is sludge in the system or the stat? (by the way, boiler was new 2 years ago, but was fitted to old system).
thanks in anticipation.
