Hi, I have had a New Worcester Bosch Heatslave 18/25 combi boiler fitted and the plumber has used a Twin Channel Digital plug in programmer and a Honeywell CM927 Wireless Programmable Room Thermostat. The problem I have is the two seem to be conflicting against each other, the only way to make boiler work is to put Hot water to ON on plug in programmer then Match the timed settings on the plug in programmer on the boiler with the wireless programmer roomstat. With this setup I cannot turn the heating on outside the times i have programmed into both programmers. I am wanting to know 1. Can I remove the plug in programmer? 2. How to wire the wireless programmer so it controls the Central Heating i.e. where do the A- B terminals go on the boiler? 3. Will my DHW still work with the plug in programmer removed or will i need to alter wiring on boiler?
Your help will be very much appreciated as i am getting no where with the plumber that fitted the boiler he says thats how it should work but I want to be able to have heating on outside programed times if i'm home early for example. Regards Martin
