U
ukdan
Hi
I have yet another problem with my combi. When the dhw is being used, after a little while the flame will go out for a few seconds and then come back on. The pump is seemingly running fine but it gets too hot to touch. I've taken the vent plug out the centre of the pump and water pours out through the hole, even with the pump off. The pump spins fine and the water, which is clean, still pours out. Each time i take the vent plug out, there is a release of pressure, even if i put it back in and take it out straight away. Am i right in assuming that the pump is knackered and just needs replacing? Also, just out of curiosity, why does the pump need to operate when only the dhw is being used?
Many, many thanks for any advice.
Cheers
Neill
Cheers
Neill
