Hi Everyone,
I need some help. I have just purchased a 24RI as a replacement for an old Glow-worm Fuelsaver, and I want to upgrade the central heating controls at the same time. It's an indirect 'y' system.
I want to install controls which give me as much flexibility as possible over setting the hot water and central heating times and room temperatures. Ideally I would have liked to install a wireless programmer, but I understand from Worcester Bosch that this isn't possible with this boiler. Is there such a thing as a wired programmer that will communicate with a wireless room stat? Failing that what would you recommend as I will need to buy a combination of wired programmer/room stat/cylinder stat. There are Drayton TRVs on all radiators apart from the hall (with room stat) and bathroom.
Finally would I get better control if I replaced the current mid-position valve with two 2 port valves for central heating and hot water.
I'd be grateful for any advice or information to improve my existing set-up.
