I have just moved into a new flat. The heating and hot water appeared to be working correctly when I moved in. I thought is would be a good idea to bleed the air out of the radiators, sigh…
I am using the user manual located at http://www.worcester-bosch.co.uk/cache/file/186/user-manual-for-cdi--discontinued-05-07.pdf as my only point of reference.
When I moved in the pressure gauge read 0 which I assume means I have an ‘open vented heating system’? How can I confirm this?
SYSTEM PRESSURE GAUGE
The red needle has been set to show the sealed system pressure which is required for the appliance to operate effectively. The grey needle will show the actual pressure in the system. This does not apply to any open vent system.
The boiler is indicating ‘overheat cutoff’ as described below:
Central heating and domestic hot water demand indicators: BOTH FLASHING SLOW : Overheat cut-off (once per second).
I reset the system by pressing the ‘Reset Button’ for five seconds and then follow these instructions:
TO LIGHT THE APPLIANCE
Check that the water valves to the central heating circuit are open. On sealed systems check that the grey needle on the pressure gauge is not below the required pressure. Switch on the mains electricity. The green power on indicator will light. Set the room thermostat, if fitted, to maximum. Turn the central heating temperature control knob to ‘MAX’. The red central heating demand indicator will light. The burner will light and the red flame detection indicator will light. Set the central heating and hot water temperature control knobs and the room thermostat, if fitted, to the desired temperature.
I have no idea how to ‘check that the water valves to the central heating circuit are open’ but I have not touched anything since I moved in.
As stated I ‘think’ my system is not sealed.
The ‘green power on indicator’ lights as expected.
The ‘red central heating demand indicator’ lights as expected.
I don’t know what ‘The burner will light’ means?
The ‘red flame detection indicator’ does not light, which is not expected as it should.
There is no heating. If I run the hot tap the ‘DHW demand Central heating indicator’ lights but there is no hot water. The ‘red flame detection indicator’ still does not light.
After a while the system appears to overheat and indicates ‘overheat cutoff’.
Any help would be gratefully received. If it is not obvious I am a complete novice so please be gentle.
