worcester bosch 24i combi
4 Jan 2008
Hello,
I really hope someone is able to help with the following.
The boiler is a Worcester Bosch 24i combi, it's not lighting for central heating and its not lighting for hot water (ie when a hot tap is opened).
It has a permanent orange light on.
the pressure gauge reads just under 1 bar.
The fan sounds like it runs ok but there is no sparking sounds.
many thanks
(I think it might be cold tonight)
A common situation on these is for the fan to run but just not enough to operate the air pressure switch.
Problem is likely to be the fan bearings and you might get a little bit more out of the existing one by lubricating them or at least the front one that you can get to.
I revived one last week and have to go back with a new fan tomorrow rather than risk it failing again over Christmas. A cap full of vegetable oil did the trick that time.
Thanks for the replies.
It's sort of fixed at the moment - the overheat button had popped out.
Pressed it back and everything is working again.
It's worked fine up til now so not sure why it would cause the overheat button to pop out
