please help,
recently my fan popped so had a new one fitted, all good, but then when the central heating as timed off, if i come to either strart it again or run hot water nothing happens, but if i disconect the red hose from air pressure switch then pop it back on the boiler fires up, but again if i let the timer run or turn the heating off, then try relight, nothing happens, i have to again take off the hose pop it on, it fires up, now a new fan was installed and i`ve tried a new pressure switch and still the same, is there anything else before i have to break with the yorkshireman rule and get in a pro. all was fine up until geting the new fan. cheers
