Has anyone fitted the heat exchanger on a 24i junior? I've removed the old one (that took a while), and confirmed that the reason for the low hot water pressure was a scaled up heat exchanger. I've now descaled the heat exchanger and am trying to refit it. Only now I realize I should have just flushed the entire hot water circuit with descaler as I'm finding it impossible to refit the heat exchanger.
Has anyone managed to do this? And is there a special technique, I can't manage to get the heat exchanger over all 4 o-rings at the same time and am unable to then refit the fixing clips, any ideas?
