- Joined
- 29 Jul 2004
- Messages
- 12
- Reaction score
- 0
- Country
Having problems with said boiler, its about 4 -5 years old no problems until a few weeks ago when i could not get any hot water unless the hot tap was turned on and off a few times, i replaced the water flow switch and everything seemed ok until last week and now the the same problems have returned only now when the hot water tap is turned on and off it takes longer for it to fire up. The fan comes on but then nothing happens it does not try to spark but carrys on running, the same thing happens now on heating if i turn boiler off at fuse spur and back on again the boilers works normally untill i switch heating off and then try and turn heating back on the fan continues to run but the boiler will not relight unless it is turned on and off again at spur.
Any help or advice appreciated before a heating engineer is called for
Regards Sammyboyblue
