Worcester bosch 28 CDi
5 Jan 2014
Sussex
Following previous thread.....
Boiler now appears to be working ok. Although.....
Small leak from near pressure relief valve and small leak from auto air vent.
Anyone any ideas?
What sort of answer did you expect? You obviously realise you need to get them fixed.
I thought that someone may say, " you shouldn't be getting water out of the auto air vent, that's wrong, there is a fault else where on your boiler". Maybe something like that????
If the water is coming out of the top of the AAV, it has failed and needs replacing. As for the leak on the PRV, I can't remember how these fit on the old CDi. if it is an O-ring seal, did you replace the O-ring?
