worcester bosch 280 rsf NO IGNITION
11 Aug 2004
please help ;theres no ignition ,no fire, no hot water , no central heating . The fan not moving ,is the boiler not working anymore? The demand & standby light is still on.
Checked water pressure on the gauge? SHould be about 1 bar.
high limit stat .cant remember exactly were it is top of boiler rings a bell i
turn power off take white panel off front look for little black circle with wires on main heat ex usually red button between wires press if it clicks it will work needs looking at tho to find out why .to late for details to many lager under the bridge hope this helps
Overheat re set button is on top of the controll pannel behind the front panel.
