- Joined
- 31 Oct 2007
- Messages
- 7
- Reaction score
- 0
- Country
I have a Worcester Bosch 28CDi RSF boiler which is about 8 years old. The pressure on the gauge drops to zero about 4-5 hours after running the central heating. I have had this problem for about 18 months and has been getting progressively worse. Initially refilling every few weeks but now daily. This problem is not coverred by the installation and fault finding mauals or any of the installers or user materials from the Worcester Bosch Web site.
My initiall thoughts were obviously a water leak! So far have pressurised the boiler as high as mains pressure would allow and inspected all over the boiler for leaks with boiler off and cold and running for hot water and running for heating. Nothing found around the boiler aside from the vent cap on the top left hand side which has watermarks from it, but oberved no significant leak. When not running the presure holds and when using hot water only the pressure holds. Also inspected the piping around the house. No signs of leaks anywhere. Luckily with a full cellar I have access to all fittings apart from the two upstairs bedrooms and there does not appear to be any water leakage marks on the plaster on the rooms below. Or leakage on any of the pipework around the house.
The diverter valve was replaced about 2 years ago and boiler has been regularly serviced as house was rented out. However not had a second opinion on this fault yet.
Could this be internal leakage within the boiler when running? Any ideas.
