Worcester Bosch 30CDI doesn't turn off
15 Feb 2011
Rutland
We have a Worcester Bosch 30CDi, installed 3 years ago and has been working fine. However, woke up the other day to find that even though the stat was set to nil, the boiler was running at max.
A bit of investigation; hot water works as normal via the programmer, but ch can't be controlled at all by it. Stat is clicking on and off happily so nothing mechanical there at least; ch stays on even when programmer is lifted off the wall and disconnected.
I'm thinking there's a stuck control relay on the boiler control board - does that sound plausible?
Thanks.
OK... That probably takes it beyond any hope I have of sussing it out! External controls beyong the stat & programmer? And which valves...
As you'll have guessed, I'm not a plumber!
I'm glad you find a perfectly legitimate question amusing.
The model 30Cdi alone could be anyone of three boiler types,and I wondered if the OP understood "conventional" correctly.
3 models?
1 combi without zonevalves
2 conventional, with zonevalves
3 ??????????
As for the amusement factor: the :LOL: :LOL: :LOL: were meant to indicate that the :rolleyes: should not be taken seriously.
id assume its a system boiler but by conventional poster means open vented.
probably your CH zone valve stuck on
Ray
Cor, didn't mean to start a fight! :LOL:
zone valve stuck on... what's a zone valve (assuming that's not what I'd call a room stat! - and where would I find it?
