- Joined
- 4 Jan 2007
- Messages
- 4
- Reaction score
- 0
- Country
Just got a 30Di combi boiler & DT20RF thermostat installed and got two problems
1. Pressing "select" is supposed to cycle between the different central heating modes (OFF, TIMED, ONCE, ON) but this doesn't work (it won't move the arrow)
I can only have central heating ON or OFF by pressing the "ok" button
I can set the times I want, but then just can't enable the TIMED or ONCE modes!
I think the "select" button is physically ok, as when pressed, it turns on the backlight on the display
Pressing the other "select" button (for hot water) works fine
2. The atenna symbol on the receiver is still flashing, when I think it should be solid (so I assume there is no connection to the transmitter) I've read the instructions, but I can't find a way to set up the RF link a second time
Before I ring the installer to come back out, anyone got any suggestions?
