- Joined
- 10 Mar 2015
- Messages
- 5
- Reaction score
- 0
- Country
3 months ago my Worcester Bosch 350 wouldn't supply hot water or heating.... The boiler sounded ok making all the correct noises but the ignition stage wouldn't kick in.
Engineer arrived cleaned/lubricated the fan and it worked for a few weeks then same problem so got new fan fitted but this didn't fix the problem.
When it happened all that was required was to switch off/on the system then it would work for a few days.
Engineer then diagnosed faulty air pressure switch which he replaced and again fin for a few weeks but didn't cure the problem.
It's been this way for a few weeks now and every time it happens switching on/off doesn't fix it but blowing down one of the air pressure tubes will fix it every time....
So currently I find that about 3 times a week I need to do this and it's ok for a few days.
I've ordered new silicone tubes but not convinced that will make much difference
What else could cause this problem? Thanks
