Hoping someone can help?
I have a 2 year old 37CDi boiler and everything was fine for first 20 months or so. Now however I have a big problem with it:
I have a dt20rf programmer installed with wireless thermostat and irrespective of the pre-heat hot water setting on the programmer, whenever I turn any hot water tap on it comes nice and hot for about 15-20 seconds and then goes cold again. I have checked the pressure and refilled it a couple of times back up to just under 1.5 on the gauge but no luck, only hot water for 20 seconds and then cold again. I leave the boiler for several minutes then go back and turn tap on and same thing happens all over again, hot water for 20 seconds and then cold. Heating seems fine when demand is on.
PLEASE HELP !!!!!ANY ADVICE VERY MUCH APPRECIATED .
THANKS IN ADVANCE
Just found out that when the heating is on, the hot water comes through perfectly fine all of the time with no drop in temp/pressure, but switch the heating off and within 20 seconds the hot water has gone cold again. Could it be the DHW sensor?
THANKS IN ADVANCE
