Our combi boiler keeps losing pressure. But not in a standard way.
I happened to check gauge recently on one day and it was fine. Then the next day I noticed it had lost all pressure. Suspected a leak. Checked ceilings etc, but nothing. Can't check under ground floor rads easily.
Repressurised boiler (took about 20 secs) and called WB. Engineer visited few days later and he repressurised expansion vessel (though I wasn't convinced he was sure that was the problem).
All fine for a few days until this morning - I noticed the pressure had dropped about 1/3 bar. Didn't do anything but returned just now to see needle on zero.
So far I've:
1) Checked for obvious leaks - ie stains on ceilings. Nothing.
2) Checked overflow pipe outside. Nothing.
Any ideas? Really grateful for help.
EDIT: My problem sounds a lot like this one: //www.diynot.com/forums/viewtopic.php?p=491337#491337 in that the pressure is also getting higher than normal when the heating is on.
So far I've:
