Worcester Bosch Burner Indicator Question
21 Feb 2011
London
Hi All
I have a Worcester Bosch 40CDi and I'm a bit worried its not working as designed. I have set my thermostat to 20 degrees on a timer and as expected when the temperature goes below 20 degrees in the correct time slot the Burner Indicator comes on and the radiators start to warm up. The weird thing is that the Burner Indicator goes off before the thermostat reaches 20 degrees? If I watch the boiler for 10 minutes or so then the Burner Indicator will come on again and then go off again a few minutes later, this will continue and the thermostat will rarely get to the desired temperature of 20 degrees.
Is this normal?
Should the Burner Indicator be on constantly until until the desired temperature is reached?
Thanks, Daniel
