When I run the hot water at differing rates and at differing settings, the water is "ketteling" in the boiler, then the system shuts down. Logic tells the water in the boiler to hot water heat exchanger loop in over heating. Is this a simple fix of replacing the hot water limit switch visible behind the hot water heat exchanger. The system does shut down so Im guessing the main boiler limit stat is working.
