Hi
Hoping for a spot of advice on our Worcester/Bosch combi. Model greenstar 30 cdi.
A couple of days ago it showed a fault F7 which the manual says is ‘flame detected even though appliance switched off’.
I’m not aware the power has been off or an intermittent power cut on the house. So pressed reset and it all cleared and started up. The pressure on the CH was showing it at just under 1 bar, so opened the tap a little in the filling loop. It came up to about 1.1 bar so left it there.
About a day later I noticed water dripping outside from the little overflow from the boiler. Pressure was showing at just over 2 bars, at the end of the thicker green bit.
I switched the boiler off and drained some water from one of the radiator taps. The pressure dropped to about 1.8, so left it there.
Since then it’s come back up to over 2 bars and continues to drip outside.
I can’t hear any water hissing, in case the tap on filling loop has somehow jammed open.
I have got a 7 year warranty on the boiler, so will call Worcester-Bosch tomorrow morning. It has been serviced every year in line with their requirement.
Meanwhile was after a spot of advice if I can here, so I do not go in cold.
Thanks in advance.
Thanks in advance.
