So we've had this boiler for around 12 years and recently it developed a leak from the internal filling loop, the sort that you had to insert a plastic key into. Anyway, had look on the net and brought a new keyless type and fitted that over the weekend. Ever since then, when the heating is called for from the programmer, the boiler heats up as you see the temp rise on the screen but the pump doesn't run! When I initially turned the boiler on after replacing the filling loop it came up with the inverted 'h' on the screen which I let run through. If I switch to the chimney sweep mode, heating works for a while. I've also tried resetting the boiler but it's not helped. Any ideas?
