Our trusty Worcester Bosch High Flow 400 pump has started to run continuously. Some have suggested a stuck valve, others a faulty pub. Is there anyway for me to diagnose which it is?
I don't remember this particular model but many boilers of that era had a thermostatic switch which provided pump over run. They are a fairly common failure point on boilers that old.
But the switch is usually inside the combustion chamber which DIYers should not be opening.
