Hi I've got a Worcester Bosch 280RSF with an overheat problem - boiler boils and reset button pops out after drawing HW.
Having read other posts on this forum previously I recently replaced the W-W exchanger thinking this was the most likely cause. The existing exchanger was reasonably clean, but I replaced anyway and, surpisingly given there was nothing wrong with the original this appeared to solve the prob. I concluded that there must have been air in the system and sat back and soaked up the praise from the missus for fixing it
Now the problem has started again, i'm assuming there is air in the system again but no amount of bleeding/running the system seems to clear it. Could it be the AAV is faulty/letting air into the system somehow? Assuming it is air, what's the best way of getting rid of it, or am i barking up the wrong tree?
Thanks in advance
Thanks in advance
