I have a Worcester Bosch R28HE installed in the garage
There is a separate Honeywell T4360a frost stat, I also understand that the boiler has its own frost stat.
I am using a Digistat RF3 and SCR receiver, this appears to be operating the boiler as it should.
The pressure shown on the boiler is normal, i.e. in the green zone when up to temperature.
It is/has been very cold here lately (min -8 over night and no more than about 0 - 2 during the day.
What's confusing, and has not been normal behaviour, is that when there is no demand for CH according to the RF3 (no green light on the SCR)the boiler continues to "run". What I mean by run is that the boiler sounds like it's running but the indicator lamp for the burner is off and I can see from the gas meter that no gas is being used. Why is this and is it likely to be some kind of fault?
For more information, I've been turning the boiler off during the day and overnight to stop the boiler heating 24/7 I assume as a result of the frost stat kicking in. Could the confusing behaviour be due to the in-built frost stat or a result of me turning the boiler off and on using the master switch?
As a follow-on question, given that all pipes in the garage are well insulated and the boiler has its own frost stat, do I really need the Honeywell frost stat?
Apologies for the long post but I've tried to supply all relevant info
Steve
Steve
