merry christmas everybody ,boiler has just sprung a leak ,the flexible hose on top of the pump is dripping at quite a rate ,pressure is showing 2 bar which is quite high still have heat from all the rads any suggestions what the problem may be regards reddog
reduce the pressure (down to 1bar) should keep the boiler going and possibly slow the leak, but check the boiler regularly to ensure the pressure doesn't drop too low.
