Hello all,
My 10 year old Worcester Combi boiler has stopped working. The Power light is on. When the thermostat kicks in for the central heating, I can hear what I guess is the pump turning, but the boiler does not ignite at all. Water pressure is 1.0 bar (cold). Same result when a hot tap is opened, all the right kind of pumping noises, but no whoosh of ignition, and clearly no hot water. however a slight (physical) tap on the boiler casing and ignition! for a while..... then the boiler cuts out and needs another hit! running hot water while the flame is on will deliver hot water but as soon as demand stops (turn tap off) then no ignition again until another hit to the casing.
Any ideas?
Any ideas?
