Can you help me please? It's frosty at home!
Worcester Hi-Flow 4.5 combi boiler. Approx 10 years old
Slight leakfrom a Radiator lock shield - to be resolved.
Pump replaced on weekend, resolved ketteling and boiler over heat protection cutting in. Pump is not a direct replacement but an equivilent, runs at higher RPM though, seems to make radiators hotter.
PRV cuts in at approx 2 bar, is this too low? Water pressure then drops below 1 bar. Not all rads heat up when the pressure is low, I think a new PRV would solve this. Intermittently the boiler cuts out, not sure why, have not been able to see a pattern yet, although I noticed this morning that it was out following a shower being used.
I think I have several problems all at once here.
