This is my first boiler installation; I know very little about the subject matter and so far had several quotes and now I’m trying to chose between 3 plumbers. I’m going for the Worcester Bosch combi, either the 37 cdi or one of the new lxi range boilers if any are suitable.
Just got a few questions to help me decide?
1. What are the pros and cons about going for a local gas safe plumber vs Worcester Accredited installer? The difference in the quote is around £700 (WAI more expensive, but the warranty is 2 years longer at 7).
2. How long should it take to power flush 14 radiators, I’ve had estimates from a couple of hours to 8 hours?
3. Is there a newer version of the 37 cdi with the lxi range?
4. Is it worthwhile spending a £100+ plus on a magnetic filter?
5. The position of the boiler will not change and all the pipe work to be replaced is in the utility room and has access to all pipes within a few meters. How long should the job take on average?
